Pipe Questions
Posted by jvmjr (My Page) on
Fri, Aug 27, 10 at 0:05
Wow there are a lot of talented people on this forum willing to help. This is wonderful. I am trying to understand pipe sizing and other pipe issues. I am gc'ing my pool (as to be able to afford it) and my helper said he always does 2" suction with 1.5" returns. I can get free 2" pipe and would like to use all 2". Is this considered upsizing? My pool will be about 39' long 15 to 20' wide, 8.5' to 3' deep. My guess is about 29,000 gallons. I plan on a VS pump. Pentair CCP 420 filter. Also I will have a slide, a small fountain and 2 laminar fountains, not all running at the same time. Ok, next question. In Oklahoma, they seem to put the plumbing in the pool shell. My concern is that IF I ever have a plumbing problem, fixing it becomes very difficult. I just assumed the plumbing would be outside the shell and under the deck. Thoughts? Thanks again for all the help.
Jay
RE: Pipe Questions
Stub the returns through the shell with 1.5" and feed the stubs with a 2". Keep the 2" outside the shell by a foot or so. Please, don't use flex pvc, even if it's free. When it fails, free won't be free anymore.
Scott
RE: Pipe Questions
Thanks Scott. No flex pvc. I do understand those issues. So the eyes in the pool that return the water connect to a 1.5" pipe? For some reason I assumed 1". I hadn't really discussed it with my plumber yet.
RE: Pipe Questions
jvmjr,
You will be able to buy directional eyeballs that install in the 1.5" pvc stubbed into the pool. The eyeball fitting comes with several sizes of openings that can be adjusted.
Good luck.
RE: Pipe Questions
If you don't trust your builder's plumbing design intelligence, then I would recommend the 2" pipe feeding the 1.5" stubs to be in a loop all the way around the pool. Each stub comes off in a T-fitting from the loop. That is the easiest way for all return lines to have equal pressure.
It wouldn't be unheard of for a pool that size, and with the water features enabled, to benefit from the use of 2.5" or 3" pipe from the pad to the pool loop/drain lines. Of course that also depends on the distance from pad to pool as well. I lack the skills to do the math, but from a long-term cost benefit aspect I bet 2.5" pipe runs would pay off in reduced operating costs with the VS pump. Example: I use a Pentair VS-3050 pump and 2" pipe on a 16K gallon pool with about 20 feet from pad to pool. I can run my pump (with no water features) for about $7.30 a month. Electric costs are not linear with flow rate. I tested for electric use at double my pool flow rate (somewhat closer to the size of your pool) and I ran $46 per month charge. Assuming Pentair equipment with automation (like Easytouch) you will be able to see the numbers and do the calculations yourself - unfortunately not until after install.
RE: Pipe Questions
Our builder use 4" for the suction and 2.5" for return for everything, main pump with solar, jet pump for spa, and waterfall. All pumps are 2hp jandy stealh. The 2hp pump for the the waterfall is total over kill, but if the main one failed, i could switch is out with waterfall pump that was my thinking at the time. Buy variable speed pump. Our pool is 16k gallon.
