| We are planning a new pool. Plan was for rectangular pool with retractable cover. Friend's pool guy gave several suggestions all of which our contractor disagreed with! Can anyone with experience/expertise see which of these concerns/responses makes more sense:
1. Is the plaster you would use instead of pebbletech the marble dust plaster?
1. The exposed aggregate plaster alternative that we discussed is not a marble dust plaster. Aggregate plasters are either a quartz or a pebble with pebble being the most durable.
| Where are you located roughly? Here in NJ, I am not a big fan of automatic covers. the things that can go wrong with them outweigh, at least in my opinion, the positives. Yes, they can, when used on a daily basis, improve safety and reduce chemical and heating costs but on the negative side, the mechanisms can break, leaving a cover 1/2 rolled up, often aren't configured for use with salt cells, cost plenty when the cover fabric needs to be replaced periodically (average life is less than 10 years), and aren't as strong as most safety covers used for Winter. The chemical usage isn't that big a cost, certainly not enough to justify it. Heat can be saved with a solar cover at night for a lot less. Automatic covers can have snow loads play merry hell on tracks and cover material. Rain will carry debris into the coffin and clog its drain. Unpumped rain will seriously wear the spooling mechanism because of the weight so an automatic pump needs to be set. A hole in the cover will let pool water out. You still need a fence for the yard. There are added installation costs such as stainless hardware and extra bonding needed when a salt cell is used. The costs will vary with the size and shape of the pool. Here in the Northeast, plastering, regardless of the material used, is best done in the Spring. The cement used hydrates, raising the pH. Left unmonitored over the Winter, scale is far more likely to form. The more time you have to monitor it, the better. This process slows with time so the more time you have to monitor it, the better. The Sun provides all the UV you will need with an outdoor pool. Adding it to the return flow is more money in their pocket only. Nothing reduces the amount of free chlorine needed in the water. You can only augment it. Chlorine kills everything. Yes, there are a couple things that can take some time but residential outdoor pools have such a small risk of being contaminated, it doesn't make sense. Large, public indoor facilities and water supplies are at a greater risk because of the lack of exposure to the Sun. UV cannot be used as a primary sanitizer. It doesn't leave a residual in the pool which is where its needed. Go with the MasterTemp 400HD. Its just bulletproof, unlike the Raypak. I prefer the Quad series of filters over the FNS Plus series. They are typically a bit larger and easier to clean. All finishes use cement to bind. A big part of cement is calcium. Water can draw calcium out from the cement. The less cement exposed, the longer the finish lasts. Plaster dust also has calcium. It tends to be softer too. Quartz can improve things but is dependent on how much is used in the mix. Pebble finishes tend to have the aggregates more exposed and thus last the longest. Compaction needs are dependent on the type of pool and construction method used. Six inch lifts are expected usually. Scott |
| thank you so much for your thorough answers and explanations! We are just outside Philadelphia so I suspect the same climate as you. We had been so excited for a retractable pool cover but now are probably leaning away based on the various info we are hearing. We have small kids, but as you say, the pool will have its own fencing which should provide adequate safety. Leaving out a retractable cover not only will save a lot of money but also allow for a non-rectangular shape. Again, I really appreciate all of your insight. |
