| We are in the process of building a house and want to add a pool at the same time. I have a quote from a company that has built a lot in the area and come recommended. We are new to any type of pool and just wanted to get input from the forum folks that have knowledge in pools.
Thank you in advance :) Here is what the quote has 96 perimeter 577 area
What are other things I need to know or ask or have concerns about
| The following are important: Equipment brand and models being used Scott |
| Thank you for the additional questions Scott- these are his answers The equipment brand we use is Pentair. We do not use flex - Schedual 40 PVC. 3in Dual Main Drain with 10in pots. There are 4 returns, returns are 2in. Rebar is 3/8in on the walls and floor with 10in centers and 1/2 4 bar and beam. Bond beam is 12in, floor and walls are 8ins. Strength of the gunite is a 6 sack mix. We use flagstone on all of our jobs, although if you would like brick it would be $800 more. The sunshelf is 6ft or custom at no extra charge. Pentair has a 3 yr warrenty. Polaris has a 1 yr warrenty. |
| If you have Pentair, then use a Legend and get the 3 year warranty. He just wants the vacation for selling enough Polarises. Scott |
| Scott correct me if I'm wrong, but I think getting an Intellibrite LED light counts toward the 3 pieces of equipment needed for the extended warranty. Then they could go with the Polaris cleaner. Of course nothing wrong with the Legend either. |
| Okay, I looked it up. What I found said you had to buy a pump, filter and one other item. Lights , cleaners, and other assorted things qualified. |
