Exiting Pool, plaster and other potential issues
Posted by caesar305 (My Page) on
Sat, Jul 14, 12 at 21:39
Hello Everyone, I am glad I found this website; it has been very helpful.
I purchased my first home about 3 months ago and am now starting to do some renovation projects. The house was built in 1957 and the pool was built in 1958. Yes..it's an old pool. I'm not sure if that is a good or a bad thing yet.. haha
I am interested in redoing the entire patio deck as it is a huge mess right now. The coping is standard concrete and the pool is in a kidney shape. My major concern is the many patch jobs I see in the wall of the pool (the pool was drained temporarily for a skimmer replacement). At least, that is what I think they are. The pool is made out of cement. (Excuse my ignorance when I convey these terms). When I knock on the areas of these patches, it sounds hollow. There are really about 30 patches around the entire pool. Considering the pool's age, is this normal? Should I be concerned? I am interested in redoing the plaster as I would ideally like to change the water color to dark blue. Also, we are planning to redo the deck with a stone material and therefore require the replacing of the coping. The current coping is an eye sore. There is about a 3 inch gap above the tile line and the coping. We found out its because the pool deck is a little higher than the wall of the pool, I suppose they decided to "fill in the gap" with a taller coping. It is starting to separate from the pool wall and you can see cracks all long the edge of where the coping meets the pool wall. We have already removed one coping and noticed we will have to fill in this gap to match the level of the pool deck. As I no longer want this gap to appear, we need to remove the tile and retile new ones a few inches higher. Another alternative which I have been searching is no tile at all. Simply plaster all the way to the top. I have heard mixed reviews of this solution and I am not sure about it although I do like the look (almost like a pond/lake type look).
The pool size is 18 x30, 4-6feet. I am confused as there are a few materials offered in my area, diamond brite, pebble tech, etc. I have researched the differences but my question is which material would help refurbish the wall and make it stronger. Do pools usually last this long? Can I expect anything else to arise in the future?
I'm looking into estimates in raising the level of the pool to match the pool deck (about 1 1/2"),installing new coping to match the stone tiles we will be placing and possibly redoing the tile. Will replastering fix the patches? Will replastering change the color of the pool to a dark blue? I have already asked one pool builder these questions and the answer seems to be yes although I'm not sure if he was just trying to sell me a product or not. (Diamond brite seems to be the product he is offering). More or less, what would be the cost of doing all the above mentioned items? the first quote came in about $5,000 with no materials (no coping materials, I need to purchase it separately).
Any insight would be appreciated. (I live in Miami, Florida in case that matters)
Thank You!
-Caesar
RE: Exiting Pool, plaster and other potential issues
A picture will help immensely. A Photobucket album would be ideal.
It sounds like a strip down of the major components. While the pool can be redone, add up the work and compare it to putting in a new pool. It might make more sense.
Scott
Here is a photobucket album as per your suggestion.
http://s1271.photobucket.com/albums/jj626/illizit/Pool Repairs/
Thanks
The height change is because there are two distinct deck surfaces, one on top of the other. Like you said, its gone.
The coping is toast but can be replaced. This often gets you some chipped tile.
The finish is a delaminating Diamond Brite. It will need removal and replacement with a new plastering finish, whatever finish you choose, be it plaster, colored plaster, and the varying levels of higher aggregate finishes that are available.
Given the coping and plaster are toast, I would strongly urge the tile go too.
The shell seems OK.
Is there copper plumbing? If so, replace it.
Since the deck is going, adding a bond wire to the shell, light, ladder cups, and equipment pad should be done. In terms of work, it's not that big a cost.
What equipment is there for the pump and filter?
Scott
First, thank you for very much for your assistance, I appreciate it.
As far as I can tell, everything is PVC. I have 3 inlets: A drain, vacuum port and a skimmer. They all go to a Hayward pump 1HP, then a standard sediment filter and it comes back to the pool with two outlets.
As far as the tile, I was thinking of just removing it completely and increasing the water line so it can be as high as possible. What do you think of this?
Would replastering the entire pool "fix" the patches? I guess what I mean is, will they smooth them out and remove that "hollow" sound or is that not even a serious issue?
Thanks
My father just replastered their 1968 concrete pool, and installed midnight blue pebble tec. When the did this, they used a high pressure water jet to take off about a quarter of an inch of the concrete, and then applied the PT. The process will smooth out any irregularities of your existing concrete. (you should still determine if those areas are cracks or leaks though)
Also, from what I have read, plaster must remain submerged below the water for it to not crack. Watch out for this though, as my Father found two PBs that would do it this way, even though it voids the PT warranty! Sheesh!
