Intex pool help
Posted by cjra (My Page) on
Tue, Jul 10, 12 at 20:45
As much as we'd love a "real" pool, for now we settle for an above ground Intex 15ft x 36". I've searched many places for help on this, but any discussions seem to refer to the bigger intex (4ft deep) which has a different pump. I can't find the exact pump, but it looks like this http://www.intexcorp.com/index.php/home/above-ground-pools/agp-accesso ries/cartridge-filter-pumps/58603e.html
We're having a really hard time controlling algae this summer. It's always a challenge, but this year seems to be the worst. That it's above 100F most days doesn't help, the water gets very warm.
Tried shocking, algacide, clarifier, chlorine...
The vacuum is the mesh bag attached to hose type, which seems to be the only option for this size pump. It works well to pick up debris, but the algae is so fine it goes through the mesh. Is there another option I haven't found?
Any suggestions on how to get rid of the algae?
RE: Intex pool help
Actually, it's the 1000 gallon filter pump, which still won't handle a bigger vacuum.
Could we attach a bigger pump to this size pool?
Here is a link that might be useful: Pool pump
RE: Intex pool help
We have an in-ground pool, so I am not sure on how the procedures differ, but I have to ask - when you say you tried shocking, do you mean you added some shock chemicals or did you do the process of shocking the pool until your overnight chlorine loss was less than .5 ppm?
If you are looking to learn more about defeating your algae, read up on the Pool School at the website for trouble free pool, it is extremely helpful. We just had to shock our pool (which is a process, not a one-time add of shock chemical) and we cleared our lime green pool in just over 48 hours.
My first thoughts are that it's not the pump, it's the shocking process, but my apologies if I'm overlooking something you've tried already. We'd had cloudy pool water for about a week, (I even broke down and added clarifier!) and my husband started saying "it's a problem with the sand filter! the pool store guy says we need new sand!" and I'd fought hubs on it, since most online forums say you pretty much don't ever need new sand. Woke up to a greenish tinge on the 8th day, so then, we followed shock procedures very closely. From Thurs night to Sat night, continuous testing and adding chlorine, and woke up to a sparkling clear pool. (Same filter! Same sand! ha ha!)
