Mon, Jul 16, 12 at 19:17
| I have a inground pool and spa and have the color logic lights. The one in the pool trips the GFI and the one in the spa comes on but blinks and is not working right. I pulled the one from the pool and in worked one time being out of the pool. I put it the water and it still worked. So I put it back in the socket and it stopped working again. I pulled the covers off the GFI and swithes and tighten the wires. Still not working. They are about four years old. Help |
| 1) Hayward Color Logic fixtures did have some lens gaskets that leaked after some years. Because it happened after the warranty period, the owner was stuck with the replacement costs. 2) Disconnect the power at the deck box of the pool fixture. Does the problem with the spa continue? 3) Did you swap out the GFCI? Scott |
