| Hi--I have a Polaris 180 that is driven by a booster pump switched by an old-school Intermatic timer. Power failures in my area have sometimes caused the booster to run when the IntelliFlo filter pump is off.
What I would like to do is have the booster pump switch on when the IntelliFlo begins a high-flow-rate feature. Is there any simple off-the-shelf pressure-switch or flowmeter-switch devices that would "sense" the increased flow rate/pressure and just switch the booster pump on/off? I *don't* want to add another controller to the system--the IntelliFlo pump seems very capable by itself. |
| It woudln't be that hard to do. First get one of these.... http://www.amazon.com/Tecmark-Universal-Pressure-Switch-Fittings/dp/B0 03BGLD8I Then, run the power to the booster pump through a 24vac relay. Run power from a 24vac transformer through the pressure switch, to the relay. Set the pressure switch at 8+ psi so that it makes sure that the pump is running before it allows the booster on. |
