| Pool Size: 20x36
Pool Depth: 3.5 - 5.0 - 8.0 Area of Pool: 555 Sq. Ft. Spa: 5 x 8
Filter: Jandy DEV 60 SQ FT DE Filter
Pool Light: Jandy 500 Watt Pool Light w/GFCI and lens covers
Beam: 4 bar box beam with #4 rebar continuous
Plumbing:
All electric included
Coping: Choice of bullnose clay fired brick or flagstone
Type of decking: 3/8 inch peagravel
Pole: 8' to 16' telescoping pole
MISCELLANEOUS:
Start-Up Chemicals:
OPTIONS:
Total Bid: $49,555.00
| I see you have an upgrade for the fusion soft 40K Salt System. It is mineral based with a chlorine dispenser. It is not a salt water chlorine generator. Do you want this ? http://www.poolproducts4less.com/nature-2-fusion-soft-salt-water-sanit izer-mineral-pool-system-kit-40k.aspx You will have a Jandy PDA 8 remote. It would make more sense to me if you have a salt pool to use the Jandy aqua pure control center and a jandy salt chlorine generator which will handle all of your sanitizing needs, assuming you maintain the chemicals properly. At that point, with the control center I would ditch the standard white lights with covers and maximize the potential of your remote and control center by using LED lights that will let you run a fantastic light show in your pool and spa as well as control your Polaris cleaner and water features, spa etc. Ask your builder about this stuff, he/she should know. Personally, I would ditch the ozone. Cannot imagine why you need 3 levels of sanitization? Chlorine, mineral and ozone. 2 cents. |
- Posted by womanowned (My Page) on Sun, Jun 5, 11 at 0:05
| read the posts by CakeLady |
| Sounds like this PB might be trying to sell us stuff we don't really need. We just told him we wanted a lagoon style salt water pool. I know nothing about pools, so it is helpful for those of you that do to give us feedback! I so appreciate it! I will research the upgrade to figure out what that is all about? I just want a salt water pool that is easy to maintain. So, those lights are not color? I definitely want the color lights. Looks like I have some research to do. It is a little overwhelming! Thanks tremendously! Any other input is so greatly appreciated! |
| This is our first time building a pool, but I would give Pearland Pools and Backyard Amenities a call. Both have great reputations in the area (I am in LC too), and both are straight shooters and honest. We ended up using Pearland, and couldn't be happier. I have a thread somewhere on here - New Build - League City. Check it out, and you can see what a "work in progress" by Pearland. |
| This is a Backyard Amenities bid. I have very similar items included in my bid such as the $1450 fushion soft salt system and $700 delzone ec2 system. What did you end up going with and are you happy with your choice? |
