JOIN NOW LOG IN
Blogs Forums Photo Galleries Ask The Experts FAQs Tools & Directories
Pool Specs - League City - Thoughts/Opinions?
Posted by playa7 (My Page) on
Fri, Jun 3, 11 at 19:22
Pool Size: 20x36
Pool Depth: 3.5 - 5.0 - 8.0
Area of Pool: 555 Sq. Ft.
Spa: 5 x 8
Shape: kidney
Raised : 12"
Spa Wall: tile, brick or flagstone
Filter: Jandy DEV 60 SQ FT DE Filter
Pump: Jandy Plus HP 2 HP Energy Efficient Motor
Valves: Jandy Maximum Flow Backwash Valve
Skimmers: Two - Bermuda Skimmers w inch separate lines
Tan Skimmer lids to match deck
Pool Light: Jandy 500 Watt Pool Light w/GFCI and lens covers
Spa Light: Jandy 100 Watt Spa Light w/GFCI and lens covers
Main Drains: 6 - Main Drains - Separate lines and valves
Inlets: 5 - 1 1/2" Jets with adjustable eyeballs
Time Clocke: Jandy RS8 w/PDA Wireless controls with remote
Spa Jets: 6 Hydro Air Venturi spa jets with 1.0 HP Polaris QT Blower
Heater: Jandy LX1 Thermostat Electronic - Gas 400,000BTU
Cleaner: Polaris 280 w/booster pump
Chlorine Feeder: Rainbow 320 inline chlorine feeder
Beam: 4 bar box beam with #4 rebar continuous
Walls/Floor: #3 8"x8" on center both ways with #3 alternates
Gunite: 6 to 1 cement to sand ratio
Gunite (beam): 12" minimum, 8" cove
Gunite (walls /floor): 6" minimum
Steps/Benches: per plan
Plumbing:
2" suction,separate lines , separate valves
PVC Schedule 40 on all pool piping
PVE Schedule 80 on all pump connections
2" returns to 1 st "T"
All electric included
25 ft. gas hook up included
Coping: Choice of bullnose clay fired brick or flagstone
Tile: 6" water line tile - $6.00 per sq. ft. allowance
Tile: 2" tile trim on steps and benches - choice
Interior finish: White Marble Plaster ( Two Coats)
Type of decking: 3/8 inch peagravel
Area of decking: 955 sq. ft.
Additional decking: ADDL. Sq. footage $7.25 per each
Steel schedule: 16 in O.C. both ways
Pole: 8' to 16' telescoping pole
Wall Brush: Heavy duty gunite brush
Leaf Net: Deluxe skimmer net
Test Kit: Deluxe 5-part DPD test kit
MISCELLANEOUS:
Underground 1/2" fill line to hose bib with vacuum breaker
Concrete equipment pad poured in place
Start-Up Chemicals:
25 LB DE, ACID, 6 LB. STABILIZER, 4 LB. TABLETS, 12 LB. SHOCK, 1 QT. METAL OUT
OPTIONS:
nO REROUTES/NO LANDSCAPING and no tree removal included
Concrete for arbor area included
Eight foot dive included
3.0 ton moss rock waterfall with pump included
Moss Rock stacked wall included
sunshelf 6 inches of water and one spout included
$1450.00 upgrade to fusion soft 40K Salt System included
$1800.00 upgrade to white based quartzscape included
$700.00 for Delzone Ozone EC2 included
4 FT stacked flagstone spa spillway included
Total Bid: $49,555.00
Would love thoughts and opinions on these specs. We are trying to decide between this builder and one other. Thanks!
RE: Pool Specs - League City - Thoughts/Opinions?
I see you have an upgrade for the fusion soft 40K Salt System. It is mineral based with a chlorine dispenser. It is not a salt water chlorine generator. Do you want this ?
http://www.poolproducts4less.com/nature-2-fusion-soft-salt-water-sanitizer-mineral-pool-system-kit-40k.aspx
You will have a Jandy PDA 8 remote. It would make more sense to me if you have a salt pool to use the Jandy aqua pure control center and a jandy salt chlorine generator which will handle all of your sanitizing needs, assuming you maintain the chemicals properly.
At that point, with the control center I would ditch the standard white lights with covers and maximize the potential of your remote and control center by using LED lights that will let you run a fantastic light show in your pool and spa as well as control your Polaris cleaner and water features, spa etc.
Ask your builder about this stuff, he/she should know.
Personally, I would ditch the ozone. Cannot imagine why you need 3 levels of sanitization? Chlorine, mineral and ozone.
2 cents.
read the posts by CakeLady
Sounds like this PB might be trying to sell us stuff we don't really need. We just told him we wanted a lagoon style salt water pool. I know nothing about pools, so it is helpful for those of you that do to give us feedback! I so appreciate it!
I will research the upgrade to figure out what that is all about? I just want a salt water pool that is easy to maintain. So, those lights are not color? I definitely want the color lights. Looks like I have some research to do. It is a little overwhelming! Thanks tremendously!
Any other input is so greatly appreciated!
This is our first time building a pool, but I would give Pearland Pools and Backyard Amenities a call. Both have great reputations in the area (I am in LC too), and both are straight shooters and honest. We ended up using Pearland, and couldn't be happier. I have a thread somewhere on here - New Build - League City. Check it out, and you can see what a "work in progress" by Pearland.
This is a Backyard Amenities bid. I have very similar items included in my bid such as the $1450 fushion soft salt system and $700 delzone ec2 system.
What did you end up going with and are you happy with your choice?
