| We have a 35,000 gal concrete pool. We found out the nitrates are high, 58 after draining down a foot below the skimmers twice. The pool store I just brought the water sample to this time said the only way is to completely drain it.
He said there are plugs to take out as soon as we can get to them to make sure it balances the water table. Is this something we can do or should we get someone to come do it? How aggressive do we have to be in getting the bottom plugs out? If water comes up after we take them out do we just leave that water in or try to pump that out as we are filling it up? Has anyone drained it for this or other reasons?
| Why do you need to drain? High nitrates or phosphates can surely feed algae, but with proper chlorination, algae wont form. There is a super handy chart at trouble free pool dot com. try googling "cya chlorine chart" |
| The chlorine binds with the nitrates and becomes inert - we have shocked the pool and the chlorine is still at 0. We can keep it this way but would use a lot more chemicals to maintain it. If we did not hit water when we built, are we probably going to be ok with the water table now? |
| It even says on that website "At very high CYA levels, over 80, a partial drain/refill to lower the CYA level is usually required." |
| You didn't finish shocking. Something is in the water. Anytime free chlorine combines with something, be it bio-badies or tanning lotions, it becomes inert. Nitrates mean zilch. Killing the algae before it can eat solves any issue there. If its a bio-badie, the time spent draining and refilling will give the bio-badies the opportunity to reproduce. If you have a salt cell, your CYA is perfect at 80. If you are tablet fed and not in the Southern latitudes, then diluting will be needed to reduce the CYA level. With your current level of CYA, bring the FC level to about 40 and hold it there until you can pass the Overnight Chlorine Loss Test. If you can take the calcium, cal-hypo can be used. I prefer using bleach (6%) or chlorinating liquid (12%). Scott |
