Did I make the right Choice? Variable Speed pump.
Posted by acw6455 (My Page) on
Fri, Jun 8, 12 at 13:17
I am trying to upgrade my pool step by step, but yesterday was my little splurge.
Currently
Filter: Pentair Quad DE Filter 60sqft. (new)
Heater: Sta-Rite Max-E-Therm 400,000 BTU Natural Gas (new)
Vacuum: Suction Barracuda Mx8 (old)
Pump: Hayward super pumpII 3 hp (old)
I just bought four new items and I hope I didn't go wrong.
Pump: EcoPump EP-6 http://www.poolexpress.com/pumps/ecopump-ep-6-energy-efficient-ingroun d-pump/
Sanitation: SpectraLight Pool UV Disinfection System SL-600
http://www.poolexpress.com/ultraviolet-pool-systems/spectralight-pool- uv-disinfection-system-sl-600/
Vacuum: Dolphin Premier Robotic Pool Cleaner
http://www.poolexpress.com/automatic-pool-cleaners/dolphin-premier-rob otic-pool-cleaner/
Did I make a mistake?
RE: Did I make the right Choice? Variable Speed pump.
EcoPumps are basically overpriced two speed pumps. The motors use a run capacitor for the low speed which helps low speed efficient but not enough to make a big difference when you compare it to a regular two speed motor. You might save 20% on low speed but low speed uses such little power anyway, saving 20% doesn't amount to much in terms of $.
Plus you can now get an A.O. Smith two speed motor with dual run capacitors for around $300 so you could just upgrade your current pump with a new motor and perhaps a new impeller/diffuser.
I am not a big fan of UV systems because in order to do any good, you need to run pump which is more electricity. Chlorine is the only sanitizer required in a pool.
The robotic cleaner is probably the best choice you made. It can run without the pool pump which is a big plus.
Here is a link that might be useful: AO Smith Motors
