Intellichlor Not Running In Solar Mode
Posted by concretehole (My Page) on
Sat, Jun 18, 11 at 13:03
I have the full Pentair setup and I have added a relay to my panel to setup a lower speed cleaning mode for my pump, I use the solar mode to activate this realy. The IntelliChlor will light up when this mode starts but does not show it is producing chlorine. Is there a jumper that I can pull from the circuit board that will keep the Intellichlor always producing? I don't care if this means I will have to adjust my settings on the IntelliChlor and not be able to use my remote on this device.
RE: Intellichlor Not Running In Solar Mode
I think I figured it out. I just popped off the jumpuer coming from the main control board to the small IntelliChlor board J1. This still allows power to the IntelliChlor when the power is on but no longer allows signal from the control board.
