Wed, Jun 1, 11 at 9:09
| On our remodel project, we had a contractor completely remove the old and pour a new concrete deck, followed by Preferred Deck coating. The deck was poured on April 5. A few weeks ago I noticed a small crack going from the skimmer to the edge of the pool, and from the skimmer to the next expansion line (see image below). In your opinion, is this a concern or acceptable for a brand new deck? The crack was there before the application of the coating. I'm a little worried because applying the coating did cover it up initially, but it is now visible again.
Thanks for your input! |
| xjrule14, Any interuption in a deck such as a skimmer opening opening are prime targets for cracking. I'm surprised that an expansion joint was not placed from the pool to the skimmer and skimmer to nearest expansion. It's a common error that deck contractors should be aware of. Coatings applied to the concrete will not fill any existing cracks. Any other cracks that existed before will show up again. Proper repair would consist of replacing that section of deck that is cracked and providing the proper expansion joints. Fortunately, most coatings match very well. Good luck. |
