Aqua Logic PS-4 Control - clock problems
shuffu (
Sat, Jun 9, 12 at 1:10
| Has anyone had a problem with the Aqua logic controller not keeping the correct time. Every time I set the time the time is off (behind) up to 4 hours. I am having to reset every 12 hrs so that the timer comes on at the set time. Any advise/suggestion will be greatly appreciated. Thanks |
RE: Aqua Logic PS-4 Control - clock problems
| My AL was doing teh same, go to the main unit and check the backup 9v battery, that was my issue, it was out of juice. |
| My Aqua Logic PS4 main unit does not have a back 9v battery? |
| Are you where 50Hz power is standard, such as Europe? Scott |
| Yes, mine is doing the same. I have checked the main circuit and No 9v back up battery. Any clues? |
| Is it running fast of slow? Scott |
