Finally diving in...
jwag1130 (
Thu, May 10, 12 at 23:01
| Planning on signing a contract in the next 24 hours. I've really enjoyed reading the information posted. I would love any input!
Free form pool
Perimeter: 110'
Depth: 3'6"-5'6"
Length: 40'4"
Width" 23'8"
Square feet: 640
Spa: Freeform 8'X11'6" Freeform, 1 step, 9'Spillway, Raised 18"
Coping: Flagstone Coping
Finish: Wet Edge Satin Matric
Pool Pump: Hayward Tristar 2 Horsepower 240 v
Filter: Hayward 60SQFT Diatomaceous Earth
Pool Lights: 2 Hayward Color Logic LED lights
Spa Light: 1 Hayward Color Logic LED light
Heater: Hayward 400,000 BTU Propane Gas Heater
Skimmer: 2 Pentair skimmer
Return Fittings: 5 Hayward Pool Returns for pool, 7 waterway Therapy Jets in spa
Sun Bench: Large sun bench with 2 Jets as fountains
Main Drains: 4
Cleaner: Polaris 280 Auto Pool Cleaner
Controls: PS8 Hayward Control with hand held Aquapod Romote
Chlorine Gen: Hayward/Goldline Cholorine Generator System
Deck:750 sq ft of exposed aggregate
Steel: #4 size 4-Bar Box Beam
#3 size shell tied 8" OC
Steel placed in steps/bench
Dowels for deck every 24"
Gunite: 6 Sack mixture
12" Wide Beam
8" Wall Thickness
8"Floor Thickness
Plaster 1/2" thick Wet Edge
Deck: 5 sack mix 3/4" rock, steel in deck (no wire)
Steigmier Plastic Expansions Joints
$54,850
RE: Finally diving in...
| College Station, TX (about and hour northwest of Houston). |
| I think the variable speed will better suit your needs. During normal circulation, two horse power is about one too many and so, the slower speeds will save you money on energy usage. The higher speeds will be nice for the spa but will use more electricity. No need. Make sure the multiport has more than four positions. Why are there 4 drains? There is only one primary pump and the booster for the cleaner. You only need one set if there isn't a second pump unless you are planning for the future. Scott |
Day 3
| Starting to see the light at the end of the tunnel! Tile and Coping being installed. http://i1144.photobucket.com/albums/o481/jwag1130/IMG_6187.jpg Plumbing http://i1144.photobucket.com/albums/o481/jwag1130/IMG_6184.jpg Decking http://i1144.photobucket.com/albums/o481/jwag1130/IMG_6190.jpg http://i1144.photobucket.com/albums/o481/jwag1130/IMG_6194.jpg |
| How exciting can't wait to see finished project. |
| wow...you must be sooo excited |
| Pool looks great! I like the tile color. Do you happen to know what kind of tile that is? |
| @jwag1130: Don't know if you're still responding but I wonder if you could answer which of the Vidrepur Fire Glass tiles you used. Was it the lighter or darker shade? They look really nice in your pool. Thx. |
