Thu, May 17, 12 at 21:10
| I have a spa/pool combo... the spa, spills over to the pool. The pool and spa are salt water, do I need to add additional chemicals to the spa? Generally we are not going to heat it a lot, maybe just a few times a month... Thanks! |
| Not usually. If you have automation, it will turn the cell down or off. If you don't, manually do this when the spa is on to Off or its lowest power setting. Add a pint of bleach if it's been over a 1/2 hour in the spa, wait 15 and then put it in its normal mode, Scott |
