Sat, May 19, 12 at 16:17
| Ok we had had electrician come out and hook up an easytouch. Problem is he dont know how to program it I read through start up steps etc and did them but when i press filter button it lights up and dont come on I checked there is 220 to relay but line out of relay no power for some reason relays are not working and valves actuators are not either we spent alot of money so far can someone Please Help. |
| also I checked all valve wire are in correct slot to circuit board. |
| I should say my question is should the easytouch start working right after install for single speed motor, pool light and air blower or does it need to be programed for actuators and relays to work? |
- Posted by muddy_water (My Page) on Sun, May 20, 12 at 7:52
| You will have to go through and program all your circuit names/ Functions and then the Settings.... |
