Ground water entering at skimmer collar!
Posted by edweather (My Page) on
Mon, May 16, 11 at 15:17
With all the rain this spring, and with the water table being almost at the surface, today I noticed that dirty ground water was flowing into the skimmer from where the adjusting collar attaches to the top of the skimmer body. I'm assuming this shouldn't be happening. Should I wait until things dry out and try sealing it with something like a 2 part epoxy?
RE: Ground water entering at skimmer collar!
Nope. Leave it. It should do it. When you replace the deck, a bazillion years from now, the skimmer will be safe and a new collar can be set in place.
When the water table drops and the pool is overfilled, it can let water out too.
Scott
Thanks for the help. Let me ask a stupid question. If we won't be replacing the deck for a gazillion years (we plan on moving in 7 years anyway,) what's the harm in sealing it? It seems to do more harm than good, because we seem have a high water table often and the ground water is constantly ruining the nice pool water. When the pool does get too full I usually have my eye on it and let water out, plus the amount that will flow out of the skimmer is minor compared to what comes in.
If the water flow that could leave is minor, so is the water that could come in.
The aren't meant to be sealed.
You need a de-watering solution, not a perceived cure. Your idea of sealing is well intentioned but wrong. Getting rid of the source is the solution.
Scott
Scott thanks.
Except that the water that is entering is brown, and that's the problem.
Anyway, I am taking your good suggestion of leaving it unsealed. There are plenty of times during the fall, winter, and early spring that the pool is over full. I always wondered where the water was going when the level dropped after being full to the brim.
Also, maybe the collars are not meant to be sealed to leave a little room for deck movement during freeze/thaw cycles. I'd hate to lock it in and then have the skimmer crack if the deck moved a little.
Thanks again for your time. Ed
