SunTouch and IntelliFlo VF
Hello Everyone,
September of last year, after doing a lot of research, I purchased a IntelliFlo VF. At that point in time it seemed the right decision, but now, I do not think so.
I have a 20 year old Anthony pool/spa, with the origional Anthony heater and large DE filter. I figure it at about 13,000 GAL. All these years it had a 2HP rated pump. It also has a Polaris with the booster pump. Every thing controlled with mechanical timers.
At the end of last year, I installed solar. The solar was installed with no automation. Wanted to see how the system would react with the solar installed using the new VF pump.
So the two additions to the system were the IntelliFlo VF and the solar. Between priming and the running of the pump, it would run fine some of the time, but most of the time the pump did not like any combination of primming and running in the filter mode.
The pump works perfect in the manual mode, 100% of the time. With or without solar in the system.
The pool has basically been shut down since late last year. Now I would like to add automation, but the IntelliFlo VF is now the problem.
I have had many calls into Tech support, last year and now again this year, and they say they will swap out my speed drive for a 4/160 one. After paying for the VF model I really do not want to do this.
My question is this: After reading a couple of posts, I get the impression that the SunTouch will control my VF model as if it were a 4/160 connected through the com port of the SunTouch. I have not asked Pentair this question, but if in fact this will work, I would like to go in this direction.
My automation needs are pretty basic as it is an older pool, and when I purchased the VF model it was mainly Energy conservation, and to be able to control the speed, and it was is stand alone pump.
Does anyone know if this is a true statement, that the SunTouch will control my VF model as a 4/160 without swapping out the speed drive????
Thanks in advance
dapooltec
repair_guy
Brenham Swimming Pool Builders · New Bedford Landscape Architects & Landscape Designers · Middle River Landscape Architects & Landscape Designers · Milwaukee Landscape Architects & Landscape Designers · Rossville Landscape Architects & Landscape Designers · Milford Landscape Contractors · Davidson Landscape Contractors · Mastic Beach Landscape Contractors · Norristown Landscape Contractors · Sugar Hill Landscape Contractors · Wells Landscape Contractors · York Decks, Patios & Outdoor Enclosures · Prescott Decks, Patios & Outdoor Enclosures · Saint Louis Park Decks, Patios & Outdoor Enclosures · Woodstock Decks, Patios & Outdoor EnclosuressocaledOriginal Author
repair_guy
repair_guy
repair_guy
octocat
dizman-1_charter_net
