| Does anyone have any experience with the Aquabrite polythermal coating from Carlton Pools?
I have a 32 year old Carlton painted concrete shoulder pool that needs repainting. My understanding is that the original paint is no longer available, and that the current paints are problematic (don't stick well, don't last long). Carlton is recommending this Aquabrite product that can extend out of the water and over the shoulder. Thanks, Steve |
| I hate paint on pools. It winds up costing homeowner more in the long run than even just plain plaster. Whats done is done though so the main question is what type of paint was used before. If this is unknown, then it MUST be sand blasted off. There are different types of paint for pools. Add that to the fact the transportation laws changed and that caused a change in the paint formulas. Some paints can cover other paints. The use of two, dissimilar paints will wind up with poor results.For example, a pool that has chlorinated rubber paint cannot be repainted with epoxy paint. It would fall off in short order. Properly prepared surfaces stick just fine. The rep at Carlton is full of bologna. I have to wonder how many pools he has done, soup to nuts. Read the following linky. I have used their products and Sau-Sea products with good results. Cheap is what you get if you go with cheaper stuff. Doing it twice always costs someone and painting a pool is no exception. Scott |
Here is a link that might be useful: Olympic's tutorial.
