Fri, May 27, 11 at 9:33
| I went out to check the pool equiptment last night, opened 2 weeks ago and the intellichlor was not working, no lights were lit up. Any advice will be very much appreciated! |
| Try unplugging the com wire. Then shut off power to the intellichlor powercenter (whether thats a stand alone powercenter, or part of an Easytouch or Intellitouch). Get it powered off. Plug com wire back in. Power up. See if you get some action, or let us know what you get. |
- Posted by muddy_water (My Page) on Fri, May 27, 11 at 23:00
| Turn off the power and where the intellichlor plugs in to the power center look behind it and you will see a fuse cap remove it and check the fuse. If it is blown remove your cell and clean it. Then reinstall and put in a new fuse and power it up. |
| Thank you both, I will try both this afternoon and let you know. Thanks! |
