Wed, Apr 27, 11 at 21:11
| Hello, I have a goldline salt system, installed about three years ago. I am having a strange problem and I am hoping for some help. When I turn the pump on, the unit flashes the red "low flow" light for one minute (expected). The green light "generating" comes on for 10 seconds, then all the LED's go dark. The lcd screen still displays information and by pressing the button you can scroll through screens. But, based on the green growth I am seeing in the pool, it is not producing chlorine.
Any ideas? Thanks! |
| Check the Diag screens for voltage and current. Test your water for FC, CC or TC, pH, Alk, CH, and CYA. If there is no FC, use bleach or 10/12% liquid Chlorine to bring it up to shock level, not powdered or tabs. Use the Pool Calculator to determine how much you need. Check the salt level too. Scott |
Here is a link that might be useful: The Pool Calculator
