Fence Question
Posted by JeremyLin (My Page) on
Sun, Apr 15, 12 at 20:23
I have a fence that separates my main patio area from my pool area, which I keep closed when little kids are over the house. However, when I have parties, I like to keep the double gates open on the fence. Any suggestions on what to use to hold the gates open??
RE: Fence Question
For a chain link:
You could drive a piece of 1/2" electrical conduit in the ground about a foot to 18" and use a 2' long piece of aluminum rod as a holder on each side. The rod would stand about 6 to 12 inches high and catch the fence near the bottom. Both are in Home Depot or Lowes.
For a wood or vinyl:
The fencing section in Home Depot and Lowes will have what you need to attach to the fence. Again, put conduit in the ground to hold the rod attached to the fence.
Scott
RE: Fence Question
It's a black aluminum Jerrith fence. Would something similar to what you explained still work?
RE: Fence Question
I am assuming you're not doing the fence yourself. The installer should have a similar method for holding the gates open available. Use my description for the wood/vinyl fence as a guide. The installer may have a different solution too.
Scott
