| The Pentair IC works very well when new but we run our pool 365. Our unit is dead now, 3rd season, and I am told to expect the IC 40 Chlorinator to die about every 2 to 3 years. Has anyone ever seen anything or know of a way to put the IC 40 into a mode that is just on at all times and will bypass all the salt and chemical testing. I am an electronic tech and I know there must be a way to put power to the electrodes at all times. If it was on the 8 hours a day we run the pool it should produce about the right ammount of chlorine. Also I could check levels every few weeks. I like the unit but shelling out $550+ every couple of years sucks. |
| First, Dead? What do yo mean by dead? No power? Not producing? Eaten by bear? I am a little confused by what you are asking. I have had many IC-40 running for a long time and have not had anyone call me to say it died. I would expect min 3 to 5 years from this if not abused. Again have many out there longer then that. I tell all of my customers that the money they are saving by not using chlorine tabs ect will eventually go back into a new cell. |
- Posted by concretehole (My Page) on Sun, Apr 3, 11 at 2:13
| Dead means no longer producing chlorine. No mattar how clean the unit is the service light just continues to be red and and no chlorine is produced. If I could just figure out how to power the plates all the time this unit would be producing chlorine the whole 8 hours my system in engerizied. I was not aware the plates reverse polarity, this could be a problem. $550+ buys a lot of chlorine. |
| The unit is sealed. To open it up and attempt to modify is begging for major trouble. The unit is designed for an approximate life of 10,000 hours. It sounds like you are there. That $550 isn't that much. 3" Tabs are about $2.50 to $3 a pound, depending on the size bucket. Tacking on the added costs of alk and pH increaser, periodic water dumping or reverse osmosis treatments to get rid of excess CYA that builds up when using them, and your time spent further burdens the actual cost and lost convenience of using tabs instead. Perhaps we can increase length by modifying some of your targeted chem levels. 1) What size was the cell? Scott |
- Posted by concretehole (My Page) on Sun, Apr 3, 11 at 15:15
| Do you guys know what goes bad at 10,000 hours or does Pentair just program these units to stop producing at 10,000 hours? To me it just seems like two charged plates and I can't imagine what could go wrong other than needing a good cleaning. |
| Typically, the plates' coating erodes creating a short. It's a pretty hostile environment inside the cell, chemically speaking. The life span is typical when compared to other brand cells. Scott |
- Posted by concretehole (My Page) on Tue, Apr 5, 11 at 20:35
| I wonder if anyone on this site has done their own DIY chlorinator. |
Here is a link that might be useful: DIY Chlorinator
| Another alternative is a liquid feeder like the Liquidor. Pentair is supposed to be releasing to production the IntelliChem with both an acid and/or liquid chlorine feeder very soon along with several other new products, but as is normal for any company, things sometimes run late for various reasons. Scott |
