Tue, Apr 5, 11 at 15:13
| I HAVE A PENTAIR MINIMAX NT- ITS ABOUT A 2002 MODEL
I HAVE HAD TO REPAIR IT MANY TIMES -- NOW I HAVE A PROBLEM IM NOT SURE WHAT TO DO - WHEN THE POOL HEATER KICKS ON THE PIPES COMING OUT OF THE UNIT BANG LIKE THERE IS SOMETHING BROKEN LOOSE AND THE UNIT SHUTS OFF I HAVE AN AUTOMATIC NATURE2 CLORINE GENERATOR NEXT TO IT.I CANT TELL WHERE THE NOICE IS COMING FROM. I TOOK APART THE WHOLE INLET OUTLET HEAD AND FOUND NOTHING INSIDE !! THANKS IN ADVANCE ED |
| The banging is due to an inadequate flow through the heat exchanger. This can be due to either the internal bypass failing/failed or the heat exchanger is loaded with calcium. I cannot recommend putting a new heat exchanger in this heater, if that is what it needs. Heat exchangers are quite expensive. I strongly suggest you replace this heater with either a Rheem/Ray Pac or a Pentair MasterTemp, both of which will provide you with a considerably more reliable use than the old NT series. Scott |
