spa water level drops
Posted by bhebert (My Page) on
Sat, Apr 16, 11 at 0:19
Lately I've noticed that my spa water level drops to the level of the pool when the pump is not running. It is a slow gradual drop. I have a spa that is raised 6" above the level of the deck. The spa has a spillway that circulates into the pool when the pump is running
What could be causing this? I don't believe the water is leaking out because when the pump is running the water level raises back up to the level of the spillway and the water level in the pool seem to be holding steady.
RE: spa water level drops
I had the same issue and what caused mine was a bad check valve. It was not preventing the water from flowing backward in the piping. Unfortunately for me I had a overfill drain and it drained a couple hundred gallons of water every night. Since I have a automatic filler too it went unnoticed for some time.
so the water is leaking from the spa back into the pool, correct?
Yes,
Check valve is probably the most common problem of this.
Water settles back to pool.
