Does Epoxy Putty Work For Skimmer Crack Repair?
Posted by soundstage28 (My Page) on
Thu, Apr 29, 10 at 0:04
My skimmer developed a crack about a year ago which lead to 1/2" of water loss per day. I used an epoxy putty (came in a tube. You mix by hand like dough) from the pool store and jammed it tight into the crack and overlapped by 1" and it seemed to work....for a while. Now losing about 3/4" of an inch per day and looked in the skimmer and noticed the hardened putty had pulled away from the cement. Crisp as a thick potato chip and could break it off by hand. Obviously the water worked it's way behind it.
My question is....should I just chip the old putty off and do again or is there a better product? I see ads for 3 part formulas made for basement leaks, but not sure if I need to go that far. Any suggestions? Crack is about 8" long and 1/8" wide. Keep in mind it's in the cement skimmer, not the plaster.
Thanks in advance for your help and knowledge!
RE: Does Epoxy Putty Work For Skimmer Crack Repair?
try H20 glue. Its for exactly this. works underwater, wet or dry. I am a pro pool service tech and I use it all the time. Here I found the website.
Here is a link that might be useful: h20 glue
