| I just bought this dolphin diagnostic off ebay. At first it was not working that great, and I realized from reading the on-line manual that I had the bag in wrong.
Now that I straightened out the bag, it is working better, but still not climbing all the way up the sides like it should.
It says not to run it in cold temperatures, so I wonder if it would work better if it got warmer? I'm in GA so it's been in the 50's and 60's. The water might be a bit colder.
Also, it says in the manual to "lock" the handle in an upright position. I can not seem to get the handle to lock. I can change the position but it does not "lock". Does this matter?
It just does not seem to be cleaning as fast as I'd hoped. Then again, I have a fairly dirty pool. But my old baracuda cleaner could have cleaned faster than this. Unfortunaly, the old cleaner got clogged easily by the acorns, twigs, and other debris which gets in the pool from the large number of trees near the pool.
Also, an acorn occasionly gets caught in the machine (not the suction part, but the edge where the "track" or yellow moving rolling rubber thingie is, causing the robot to work less efficiently until I take the acorn out.
Also I notice when it runs over a spot, it gets some of the debris but not all. There is a very thin layer of sand/dirt on parts of the floor and it picks that up, but leaves a little of it. Is this normal? Maybe my pool is just too dirty and I need to keep running the dolphin. It will eventually clean the pool, but I've run it for over 3 6 hour cycles and it's not even halfway done.
If it matters, I have a vinyl pool, and it's fairly large (9 foot deep and about 40 ft long). It is a salt system. I have not turned the pump on yet this year. I am just running the robot to try to clean it up a little before turning on the pump. The water looks blue and just a little cloudy, but it does not look bad other than needing a good vaccuum w/the dolphin. The water will clear up once I get the pump running.
Any input on the dolphin would be appreciated!!!!! |
