| So......Brand new pool (see spec's below).....When first filled with water, and in regular pool circulation mode, (return valve set at 75%pool and 25%spa) I could set the intelliflo to 1500rpm and water would push through both the pool, and the spa. The spa has an overflow that goes down to the pool. All suction is from pool. There is a check valve on the spa return due to it being +24" in elevation.
All of that is completely normal, right? Then, about 2 months later, I noticed that water was no longer flowing to the spa. I had to boost the RPM to 2100rpm to get water to go to spa again. Filter pressure had not changed at all, but I backwashed anyway just in case, NO CHANGE! I opened the check valve and made sure it moved freely and had no obstructions. Pool builder is stumped.
Any Ideas???? spec's:
| Which DE filter? Was that the 1st time it was backwashed? Scott |
| The DE filter is pentair....FNS60 Yes, first backwash. Pressure was only barely raised when I did the backwash. But I thought it might fix the problem. No Luck. |
| Is it possible the grids got oil coated with skin oils and tanning lotions? You may need to manually wash the cake off and soak it in TSP or cheap powdered dishwasher detergent. Are all the jets in the spa shooting water properly? Putting the spa in drain mode to a few inches below the jets and switching to normal mode will tell you. Sometimes some crud gets in the nozzles. There might be some crud in the impeller too. Scott |
