mastertemp 400 control pad reset
basshle
REMODELING GUIDESContractor Tips: What Your Contractor Really Means
Translate your contractor's lingo to get the communication on your home project right
Full StoryHelp!!!! My mastertemp 400 pool/spa heater recently faulted with the E05 fault code. Followed the troubleshooting flow chart. Replaced the thermal regulator (due to corrosion). Dismissed gas flow as an issue since this has not been an issue in past and due to recent checks of home heating system. Also replaced stack flue sensor, as most probable cause. However the control pad is constantly on now and will not clear, any suggestions beyond replacement? I know that these control pads have subroutines which can be accessed, so can someone assist here. Thank you in advance.
Citrus Heights Swimming Pool Builders · Placerville Swimming Pool Builders · Spring Swimming Pool Builders · Tucson Swimming Pool Builders · Cottonwood Landscape Architects & Landscape Designers · Hershey Landscape Architects & Landscape Designers · Billerica Landscape Contractors · Kaneohe Landscape Contractors · Lees Summit Landscape Contractors · Roswell Landscape Contractors · Wickliffe Landscape Contractors · Ferguson Landscape Contractors · Natick Decks, Patios & Outdoor Enclosures · Palmetto Decks, Patios & Outdoor Enclosures · Eustis Decks, Patios & Outdoor Enclosures
