Wed, Mar 9, 11 at 15:07
| Has anyone used granite for the spa spillway? If you did, were there any problems later?
Our last spa had a flagstone spillway,and over time starting flaking off. But I did like how it overhung about 2 inches from the face of the spa with the water flowing off it. I haven't seen, or don't know how it can be done, with just a tile spillway with the same overhang. The width of the spillway is 3 feet, so granite shouldn't be a high cost.Just don't know how well it will hold up with saltwater over time. Any thoughts, or suggestions would be appreciated.
| We use granite all the time, and its a very good material for this application. |
| My PB uses granite for nearly all his pools. He says a recent pool owner is trying a solid surface, but he doesn't know how that will hold up. I've got to get my template and start shopping around for my granite soon.... Here's a link to my blog, where there's a picture of a really pretty granite spillover. |
Here is a link that might be useful: Granite Spillover
| racket: thanks for the reply,is there anything that has to be done different when attaching the granite to the spillway, or is it just the same as doing tile? c9pilot: thanks for the info. After seeing that granite spillway, I definately want to do that. |
- Posted by carolinagirl104 (My Page) on Sun, May 27, 12 at 20:41
| We are putting in 2 granite spillways. Our problem is getting the water to flow out from the spillway instead of going under the piece of granite. Is there a special edge that needs to be finished on the granite to help this flow. |
| Geesh, it's been a year and I don't remember what my PB said about this, but he said that the granite was cut a certain way or a certain size so that the water would spill over it right - otherwise it wouldn't sheet over (flow?) correctly. I think this is what you're talking about. I would think that any experienced PB would know how it needs to be done. |
