deck foam
Posted by melderman (My Page) on
Sat, Mar 19, 11 at 14:54
My pb says there is no need for foam cushion between deck and bond beam. I read the opposite, so what's the deal?
RE: deck foam
Sounds like you are getting a canter levered deck.
There should be a membrane between the top of the beam and the bottom of the deck. There should be expansion joints running away from the edge, either the plastic type that are usually white but come in gray and tan also, or saw cuts that are made while the cement is still green.
If you are getting poured in place coping, brick or stone coping, these should have a foam spacer between the coping and the decking if it;s concrete. After a while the foam will degrade and should be removed. THe space should be filled with some sand and then self leveling compound that is elastic in nature to seal the space between the two.
Sometimes pavers may get a similar treatment but that isn't the norm in my area.
Scott
RE: deck foam
I have flagstone coping. They're planning on pouring the deck directly against the beam and coping.
RE: deck foam
Stop them. Fire them if you have. Be firm. There MUST be an expansion joint. The pool and the deck will expand and contract at different rates.. Without the joint in place, the coping will become unstuck. If some walks on unstuck coping, it could fall into the pool and onto someone or gouge the plaster finish.
Please see my previous post.
Your PB should know better. Shame on him.
Scott
RE: deck foam
Thanks, this board has saved me. I'm disappointed I even have to check behind my pb.
Thanks again and I will demand it.
If there's anything else that is a must do between deck and the finish I'm open. I guess I now want to know all the must do's so I can check him. I'm getting quartz plaster and salt system.
Thanks again
RE: deck foam
Thanks again
