| Husband and I have been getting bids for a pool in Houston. Our lot has a (small) slope - basically when you walk out the back door, you take a 3-4 inch step down and then the back of the yard slopes back up (so the back door frame and the dirt at the back fence are about the same height). The distance from the back door to the fence is about 50 feet. We have basically had 3 stories from the pool builders who have come out to quote us, and I just don't understand how they can be so different. I'm not sure which story I buy...it seems like adding 240 sf more decking (plus removing our existing paver stones) is just profit-minded, but I can't fathom how a retaining wall at the BACK of the pool would do much of anything and that is an extra cost, too.
| 3) with the 6" raised beam at the back is the only one that makes sense to me. It would stop rain water from your yard running straight into your pool every time it rains. Otherwise your yard with the slope is going to direct water into your pool. Raising the decking isn't going to stop that and seems a bit unnecessary. Hopefully someone else will chip in too. |
