Montgomery, TX - Can you look at my quote?
Posted by TXKandy (My Page) on
Wed, Mar 21, 12 at 11:11
Am I missing anything? Is there an obvious problem with this quote? Let me know what y'all think.
Thanks so much!!
POOL
Rebar 8" on center (3/8" steel)
Gunite shell with average 6" walls & floor
Tile - Choice of 6"x6" tile/standard
Coping - Flagstone
Exposed interior finish - Pebble Sheen/Primera
12�x8� Tan Ledge w/steps
5 Ton rock waterfall with grotto
(1) Benches/(1) Steps
(3) Bubblers on Tan Ledge
Lifetime structural warranty
EQUIPMENT
Pool plumbing 2" schedule 40 PVC
(2) Large Jandy LED lights
Jandy AquaPure Salt Stystem
Pentair 320 Auto-chlorinator
Jandy Stealth 2.0 Max Rated Pump
Jandy FloPro 2.0 pump (for water feature)
Jandy CV460 Cartridge filter
Automatic refill
Polaris 280 with Halcyon Booster Pump
Dedicated Cleaner Line
(1) Umbrella Sleeves
Overflow line and grate
2 Skimmers /6 Main Drains
5 Returns
Aqualink RS 6 with PDA
Electrical and Gas to equipment
DECK
Reinforced with steel
Deco drain for proper drainage as needed
Equipment pad
Deck coating - Pea Gravel/Parital Stained
7� SPA
Tiered flagstone spillover
Raised 12"
Spa plumbing 1.5" schedule 40 PVC
6 Jets
Shared 2.0 hp pump
Jandy Lxi 400 Heater
(1) Small Jandy LED light
Polaris Qt2.0 Blower
SERVICE
Final site clean
Cleaning equipment for home
Balance of chemicals upon start-up
30-day chemical and cleaning service (from date of exposed
finish)
Pool school
HOMEOWNER - Not included in quote
POA Fee
Removal of any concrete
Reroute of sprinkler/utilties
Removal and repair fence as needed
YOUR POOL:
Pool area: 558�
Perimeter: 95�
Depths: 3�x5�x7�
IA: 1033
Gallons: 20,925
Deck area: 848�
34�x 24�
Pool Price: $48,611.00
RE: Montgomery, TX - Can you look at my quote?
The bond beam specs are missing. Cut the rolled edge of a paper cup off and lift the cup. It held water but had no structural integrity. A pool is no different in that respect.
A 5 ton waterfall needs a prepared bed to sit on and additional reinforcement. It isn't stated here and is needed or the weight will press the shell into the pool.
The overflow should be connected at the autofiller. Only one port is needed in the pool. While grate is nice, it isn't normally considered a submerged suction and should not be subject to VGB compliance but every town's engineer is different.
You have two water features, the waterfall and bubblers. You have only one water feature pump listed but 6 drains. Are there two water feature pumps?
You would do better with Jandy's variable speed pump for the pool/spa combo. During normal filtration, low and slow is best but the spa will need higher speeds.
What spa jets? What size air and water loops here?
Many builders limit distances for gas and electric. Check yours and don't forget the distances needed in the home too!
I like RS-8 controllers. They can more easily be made into 16 relay systems.
I personally like seeing any 2-HP or greater pump using 2.5" plumbing on all the drains to the equipment.
Scott
Thank you so much for the info. I will def review these items with the builder. I truly appreciate your help!! You always have so much helpful information in your posts :)
