| I just signed the pool construction contract and dirt work should begin next week. Thanks all on this forum and at PoolSpaForum for the great advice that has gotten me this far. I welcome your continuing advice now and throughout construction. These are excerpts from my contract:
L-shaped, gunite/plaster "play pool": main part 15' x 32', depth 3.5' to 4.5' to 3.5'; short part will be 8' x 16', including an 8' x 8' spa with in-pool spa walls.
Pool Equipment:
Startup: Owner shall furnish water during construction and for the filling of the pool when completed. Contractor shall furnish necessary chemicals for placing the pool in operation. Contractor shall conduct all necessary plaster curing startup procedures, except that Owner will do the pool brushing during the startup period, and Contractor shall make the pool chemically balanced at the end of the startup period including adding the salt and starting the salt chlorine generation system. Again, I welcome any additional advice, ESPECIALLY before construction begins. Thanks! |
| See if he'll swap the Super II for a Super Pump. SUper IIs and 2" pipe = PITA to remove the lid. Bump up to the S310. The 270T has an inch and a half inside up-pipe and will bottle neck the rest of the plumbing. You're likely to need a second fixture in the pool. Find out how long the PBs startup period is, in writing. Have you decided on the tile and plaster? I like the idea of the spa IN the pool. Scott |
| Scott, what is the issue with the Super II and removal of lid? A Hayward rep suggested the 3/4hp Super II over a 1hp Super because the 3/4 was more efficient AND produced higher flow. Likewise, the same rep said the S270T2 has 2" internal piping. On the startup, I emailed my PB the recommended plaster curing procedures from Troublefreepool.com. Do you agree with those? On tile and plaster, my PB brought by several 6x6 tile samples to choose from. Is there something other than color to consider? What do you think works well to top the in-pool spa walls? The plaster is just spec'd as light gray. Is there anything else about the plaster I should specify? Thanks again! |
| I missed that it was a T2 which does have the 2" up pipe inside but it's still undersized for your pool, IMHO. The discharge port is in the way of the cover removal tool on the Super II with 2" plumbing. I don't like needing a special tool for the cover. I just love how manufacturers play games with impeller sizes and"Standard vs Energy Efficient"(Hayward) or "Standard vs Up-Rated" (Pentair). Same motors. Different impellers. There's a reason over 3 million Super Pumps have been put in service. Simple to work on, fairly reliable as induction motor pumps go, and easy to use and cheap. Please understand, I prefer Pentair/Sta-Rite products. But thats not to say I won't suggest what I think is right with other vendors gear. Scott |
