Electricity $0.50 KWH - what you would you do
Posted by piaa (My Page) on
Thu, Feb 9, 12 at 10:48
What a fabulous, fabulous site - thank you everyone who contributes.
I received a lot of fantastic help over on the kitchen forum and now our attention is turning to a possible pool and I have to admit I know NOTHING so please forgive me but I am reading all I can on this site.
A little background - we live on the island of St John in the US Virgin Islands and we are thinking about putting in a small plunge pool - probably 10' to 15' by 15' to 18' max and as I am in the beginning stages my first question is regarding a pool pump (need one right - told you I know nothing) Given our electricity is currently 50 cents per KWH and is expected to rise yearly do you have any advise on a relatively energy efficient pump.
Thanking you in advance - and see you soon with question number 2 :)
Piaa
RE: Electricity $0.50 KWH - what you would you do
A variable speed pump will run sloooow so as not o use much electricity. Big pipes will reduce friction loss meaning it will be easy to move the water to be filtered.
Scott
Thanks Scott - have you heard about this company?
http://www.ecopoolpumps.com/
Piaa
Yes but they don't offer complete solutions, don't use less power than either Pentair or Jandy variable speed pumps, and IMHO, have no business in the new installation market, only the replacement market and then, I would be hesitant at choosing them for my customers.
Scott
If you read the literature, they are basically describing a two speed motor that uses a run capacitor which improves the low speed efficiency. A.O. Smith now sells two speed motors with run capacitors and they claim the efficiency is about 20% better. Some of the other manufactures may start to use these new two speed motors.
The Whisperflo 1 HP full rated pump will use about 380 watts on low speed with a flow rate of 42 GPM. On the same plumbing, their 1 HP full rated pump would deliver about 42 GPM at 320 watts or about 20% more efficient which is about what A.O.Smith is claiming.
