| I'm not getting answers on other forums so thought I'd ask here.
I'd like an idea of cost to install a 5" deep 240 sq ft colored concrete patio where you are -- please say where. I know I'll have to add more to make it work for me on Maui. Thanks! |
| Assuming the following in Central Texas (from a retail standpoint, not cost to contractor): Cost of Concrete: $75/cu yd @ 4yrds = $300 Total = $2,960 Turnkey might be a little more, +/- 10% markup and you will be at roughly $3,250K Absent being in Maui, here in Central Texas this project would run between $3K and $3.5K. Albeit that is for cool decking (assuming you were putting it around a pool), for just stained or colored concrete you might reduce you cost by a couple dollars per square ft, but the cost of material and labor would remain about the same. At the end of the day depending upon your finish of the concrete, you are looking at $10 - $14/sq ft (With $10 being close to minimum) |
