Tue, Jan 11, 11 at 12:00
| When jandy goes to freeze mode pump goes to high speed. Low speed is assigned to freeze mode in program. This occurs after programed filter pump run. And freeze mode is showing on display. Low speed works normally by button or normal cycle. |
| What version code is in the controller? I vaguely remember this was an issue a several years ago. Scott |
| version MM. |
