Wed, Jun 17, 09 at 22:08
| We installed all of the 2.5"PVC pipe/plumbing and discovered that we had not used enough glue; hence, we discovered a number of leaks that we have since repaired/replaced the fittings/joints. The system is currently holding 60 psi of static air pressure. Do we have anything to worry about in the future? Should we tear out all of the pipe and replace all joints? If it is holding pressure currently will the system be safe to cover and proceed? |
| I am not a plumber but if it works now, thats all you need to worry about I would think |
