New Build - League City, TX
wamaha (
Mon, May 9, 11 at 20:40
| Well, the wife and I have bit the bullet, and have contracted with Pearland Pools for our build. We found them to be very easy people to work with, not pushy one way or another, and basically just educated us in the process. We interviewed Blue Haven, Platinum, and Backyard thru the process. We signed this morning, and are hoping to start digging in the next week or two.
Our pool will be an "L" shape due to how our backyard is laid out. Between the detached garage, and the easements we are dealing with (10' utility in back, 5' SLE on side), we pretty much squeezed in as much as we could. Specs are:
GENERAL SPECIFICATIONS:
*Pool Size: 19� x 36�6"
Pool Area: 431 Sq. Ft.
Pool Depth: 3�6" X 6�
Pool Perimeter: 103 Ln. Ft.
*400 Sq. Ft. Spraydecking
*Top existing patio w/ Spraydeck (386 Sq. Ft.)
EQUIPMENT:
Filter: 425 Sq. Ft. Cartridge Filter by Hayward; 3 yr. warranty
Pool Pump: 1.0 HP Tristar by Hayward; 3 yr. warranty
Waterfall Pump: 1.0 HP Super II by Hayward; 3 yr. warranty
Skimmer: (2) Hayward Automatic Surface Skimmer with built in Overflow
Waterfill Line: Letro Leveler
Main Drains: Anti-Vortex 8" Drain (2 in pool)
*Pool Light: (1) Colorlogic LED Pool Light By Hayward; 1 yr. warranty
Inlets: (5) Upper & Lower Pentair Adjustable Eyelets
Cleaner: Polaris 280 w/ booster pump; 1yr. warranty
Chlorinator: Rainbow 320 Automatic Chlorinator
*Sanitation: Delta UV sanitation system; 3 yr. warranty
Timer: Intermatic Dual Time clock; 1 yr. warranty
Steel Schedule: #3 (3/8") on 8" Center
Beam: 4 Bar Box Beam #4 (1/2") Steel
Gunite: 6.1 (Sacks/Sand) Ratio; 7000 psi; The gunite structure of the pool is warranted
for the lifetime of your ownership through Modern Method Gunite and Pearland Pools, Inc.
Coping: Flagstone
Waterline Tile: 6" Waterline Tile � from standard stock
Trim Tile: 1" X 1" Standard Trim Tile on steps and benches
*5� x 10� tanning ledge w/ (2) bubblers and (1) umbrella sleeve
*100 Ln. Ft. Area Drains (run to rear)
*Plaster: WetEdge Luna Quartz; 10 yr. warranty
2-ton moss rock waterfall and beam (includes booster pump and plumbing/electrical hook-up)
Chemical Start-up and Pool School
Pool Care Equipment (Brush, Pole, Net, Water Testing Strips)
Plumbing and electrical line runs included.
City Permit Fees Included.
HOA Application included.
Fence Removal and Re-Installation included.
Final site clean-up included
Any thoughts on the setup?
Image link: New Build - League City, TX (24 k)
RE: New Build - League City, TX
| Hi wamaha, did you receive feedback and how did the build go? Thinking of using Pearland Pools as well. |
