Pool Heaters
Posted by mee315 (My Page) on
Mon, May 31, 10 at 11:49
Ok so I've scoured the posts for this info but haven't seen it so here goes. I live in southeast Mass and have a 18X36' liner built in with stairs and swim-out so slightly under 700sf surface area. I've read bigger is better and I've also seen comments that haven't killed Hayward but not incredibly complimentary. I'm also a licensed plumber so I have working knowledge on the mechanics... so here's the questions:
Raypak Digital Propane P-R406A-EP-X a good choice?
Too big for my pool?
Does Raypak manufacture a 'lesser' quality heater for the homeowner that looks the same but has inferior parts? (yes it's true there are 'home depot' lines and 'plumbing supply' house lines in water heaters, boilers, etc. been to the factories and have seen with my own eyes!)
Thanks for you help!!!
RE: Pool Heaters
I have a Pentair MasterTemp pool/spa heater that turns itself on. It is not an automated system and I believe the heater turns on whenever the pump timer kicks on. This is at a second home and we have arrived after being gone for several days to find our pool heated to 105 degrees. The heater has been replaced once under warranty and other repairs have been made by the manufacturer's reps, yet the problem continues. Our only solution has been to turn the gas off whenever we leave. Has anyone experienced this problem. Thanks,
John Fedorko
