Return to the Plumbing Forum
Draining an Old Clogged Water Heater?
vgkg (
Mon, Dec 26, 11 at 16:06
Hi Folks,
Here's a good one for ya. I have a 50 gal 38 year old AO Smith water heater (yes, 38 YO! and on well water no less!) It still works ok but I'm replacing it soon. I tried to drain it several years ago after buying the home but apparently the sediment was higher than the inside outlet, so it's clogged up good, a slight drip only when fully open. I'm trying to figure out the best way to empty it cause I ain't gonna move it full that's fer sure. How's this idea sound?===
After cutting both H/C copper pipes and disconnecting the ele, I'll hook up a hose to the hot water line and lead it outside down a 6' drop to the street. Then either force air into the cold line and/or suck air out thru the hot line to start a gravity flow. Any thoughts on if this would work to empty it out ok? or is there a flow mechanism inside the heater that would stop the flow attempt.
I have considered forcing a probe/wire up into the clogged valve but it's not in the best position to do without making a huge mess, assuming it would even work?
Thanks a bunch for your thoughts on this!...and yes you can poke fun at me for having this antique :) |
RE: Draining an Old Clogged Water Heater?
Hi, Shut the water off. If you are replacing the unit open the PT on the water heater. Hook a garden house to the heater drain. Use a washing machine hose ( 2 Female ends) hook to end of garden hose. Open the heater drain if no water flows hook the other end of the washing machine hose to a hose bib. Turn the bib on and run the water backwards into the heater to loosing up the sediment. Good Luck Woodbutcher |
Thanks for the alternate idea Woodbutcher! But I'm not sure what "PT" means....pressure valve? I can see where reversing the water flow would pop thru the sediment but reclogging might occur almost immediately as this crud has had years to accumulate and thicken up. This sediment has to be a few inches deep inside there. Let me know what PT means, a little challenged on plumbing acronyms :) thanks |
| After 38 years on well water the sediment is more like a cinder block than a pile of sand and gravel. Reversing the water flow is likely to do nothing. More than likely you'll need to remove the drain valve and drive a star drill or other implement into the sediment to get the water out and it will be messy. |
| The afore mentioned ideas are great, and I would certainly try them, but in a worst case scenario if they don't work remove the treaded fittings from either the hot or cold taps on top, which will leave the 3/4" female hole open, then get a cheap 1/2" vinyl garden hose and cut one of the fittings off the end and push that hose down in the tank until it hits bottom, then pull it up just a bit use the hose to sypon the water out to a floor drain or sump pit. Once you have siphoned as much water out as you can, you will have substantially reduced the weight and you can now strap the water heater on an appliance dolly to move it. |
| The stiff wire method worked for me, but it was in an unfinished basement, so I wasn't worried about a mess. OTOH, it still drained fairly slowly so there would have been time to attach a hose. |
| Wow, thanks for the extra ideas! I may end up trying them all in sequence until one works (starting with the least messy and easiest :). But still I will need to cut both H/C copper lines before doing anything so if no one sees a flaw in my original draining proposal above it might be the first attempt. This job is still at least 2-3 weeks off so your input is still greatly valued and appreciated. Once it's done I'll let you all know how it went. |
| how does a tank that is filled with crud heat water well? |
| The crud in the bottom of the tank cooks into a solid mass like ceramic and the heat energy will go through that mass into the water the same as if you had a ceramic baking dish in your oven, however, that thick cake in the bottom also has a tremendious insulating effect so while the water heater can still heat water, the efficiency falls goes out the window as the heater has to work three or four times as long to heat the water, and if left long enough it will reach a point where the water heater can barely make warm water, instead of hot water. It must also be understood that there is a spiral deflector in the vertical flue up through the heater, which helps keep the rising heat in firm contact side of that tube rising through the water vessel, so you still get a substantial amount of heat through the vessel wall, even though the bottom of the tank is obstructed with the sludge. |
I kinda wondered about that myself, thanks for that info lazypup. The well water here is surprizingly clear as a bell and always has been since moving in 9 years ago. The previous 30 years who knows? But the bottom drain is just 2" from the floor and the lower element is about 10" above that. What I was hoping is that the sludge is lower than 9" :) The heater works well as far as we can tell, no variations noticed in temperature as we keep it on 115F. I shutter to think about the ceramic cake, ugh. When I haul it out I'll make note of the extra weight. |
update --- Haven't gotten to the point of draining the tank yet but thought I'd check back and give Lazypups idea the thumbs up for first choice. I ran into an old friend who's a Mr Fix-it jack of all trades and he too says to remove the hot water line from the heater and insert 1/2" pex line connected to the outflow siphin hose. After a bit more research it appears that the interior H/C lines do not go all the way to the bottom of the tank so lowering a piece of pex into the Hot line (the shorter of the two inside) would be best way to get the most water out.....still a couple of weeks off.... |
| You will actually do better to put the siphon hose is the cold water side. The hot water fitting has no tube in the tank, it is just a 3/4" female iron pipe fitting welded on the tank wall, but the cold water line has a plastic "Dip Tube" which extends down almost to the bottom of the tank. The purpose of the dip tube is to insure that incoming cold water will go to the bottom which forces the hot water off the top of the tank. If it didn't have that dip tube cold water would enter the top and take the path of least resistance and go out the hot fitting, thus you would get no hot water even though the tank is full of hot water. PEX tubing or vinyl water hoses are rolled, therefore the material has a natural curl. If you insert the line in the hot port that line can curl once inside the tank and the actual open end could end up fairly high in the tank making it difficult to siphon but if you insert it in the cold port it will go down the inside of the dip tube and remain near the bottom where you will be able to siphon nearly all the water out. |
| 10-4 Lazypup! Will go in via the cold inlet.....I get the distinct feeling that you are not "lazy" :) |
| Drum rrrrroooooolll...:) Well after 6 weeks of stalling I finally got er' done! My first attempt to drain the tank did good, I used the "siphon water out thru the cold or hot lines" method. The only glitch was that the 1/2" insertion pipe was too large, it went in about 3" and stopped, it wasn't crud but a junction point, maybe. Used 3/8" and did ok, took over an hour to empty. The odd thing about it was that as it was emptying (thru translucent pex line) I used a flashlite shining thru the line and did not see much crud getting sucked up, guessing most is rock hard? Thanks for the support to All of you! In a nutshell it was just 3/8" pex connected with an L to a 1/2" water hose (super glue and clap :) The end of the outflow was 5' lower than the WHeater. The best way to get the siphon started was to force water (via another hose) up the line until it comes out at the WH end, then shout to wife to unplug the water and immediately insert the 3/8" pex end into WH, I used the hot outlet, worked a-ok. Thanks again for the help! |
