| I have a cabin in Upper Michigan and every year I have to drain the water system all the way back to the pump to prevent the water from freezing. I normally open all the water valves in the building and then open the pitless adapter in the well to drain everything back into the well which works fine. I do like to repeatedly open and close the pitless adapter for the fear of losing the seal at some point and then that would involve pulling the pump and installing a new seal. I also have a Woodford yard hydrant installed on the water line between the well and the pressure tank. (the water line is installed below the frost line so that I can get water from the hydrant during winter when the underground shut-off is closed just before the water line enters the cabin). After I open all valves in the cabin, the valve on pressure tank, open the handle on the hydrant and shut the power off to the pump, all of the water will drain from the entire system except possibly the water in line from ground level to the frost line (about 5 feet) because of the check valve installed on the submersible pump. My question is: If I open hydrant valve will the water from the pipe at ground level flow up the stand pipe in the hydrant until the water seeks its own level. Then by closing the hydrant handle which in turn opens a weep hold to drain the water from the hydrant stand pipe. If this process is repeated several times will it drain the water so that any water remaining in the line will be below the frost line. It's like draining a water hose by keeping one higher then the other end. Has anyone successfully applied this method? |
| Your method sounds valid. Have considered a compressor to blow the line out? Probably be quicker and more assured of draining. |
- Posted by terrymcfred (terrymcmillenfrederick@yahoo.com) on Sat, Oct 27, 12 at 19:55
| How do we winterize a front loading stacked washing machine" We plan to winterize our cabin for the winter..for the first time...any advise would be appreciated. |
- Posted by alan_s_thefirst (My Page) on Mon, Oct 29, 12 at 1:39
| Terrymcfred, I'm probably going to have to do this myself. You'll need a couple of bottles of RV anti-freeze.... You need to rig up a way that you can connect your hot and cold hoses (mark them for the spring so you connect them correctly) to the anti-freeze - some sort of funnel arrangement.... Put it into a warm cycle, so it draws some of the antifreeze from hot and cold lines. You won't need a whole lot, then cancel the cycle and find the equivalent of the rinse/drain cycle, and it'll pump out most of the water that ran in...you can add more into the bowl of the washer as well, as insurance. If you have a dishwasher, you'll need to do the same to that. You'll also have to drain your hot water tank as well. It may be worth considering doing all that, but leaving some sort of backup heating running, just as insurance. |
Return to the Plumbing Forum
