| I have to replace an existing Pressure Regulating Valve, a Honeywell Braukmann old D06 1". This valve new part number is DS05. Please explain the following plumbing terms: single union fitting sweat Thank you for any assistance provided. Mario Fernandez |
| You can have a union connection on one side or both of the pressure reducer. If only on one side, the other would be directly threaded or soldered (sweated) to the connectiong pipe or fitting. The below picture shows an example of a union. |
Here is a link that might be useful: Plumbing Fittings
- Posted by rusty_2010_gardener (My Page) on Sun, Dec 16, 12 at 11:58
| Randy427 Thank you for your help. So a single union fitting would be a valve that has what you show on this picture on one side (INLET) which could be threaded or sweated and no union on the other side(OUTLET) just the valve threads. I hope I am right. Thanks Mario |
- Posted by lazypup (lazypup@yahoo.com) on Sun, Dec 16, 12 at 12:34
| My first question would be why are you changing the valve? |
- Posted by lazypup (lazypup@yahoo.com) on Sun, Dec 16, 12 at 13:03
| The reason that I asked the previous question is that far too often homeowners change out the entire valve when all they really needed to do is clean the internal sediment screens. Now I am sure that many will say they don't have screens but that is not true,,,,Code requires a sediment screen on the input side of a PRV. |
| On mine, the union fitting is on the OUTLET side. I don't know if they come the other way. |
Return to the Plumbing Forum
