Sat, Dec 10, 11 at 8:17
| Had an Oatey single handle washing machine valve that was about 14 years old. Developed a leak at the handle.
I was able to take old valve off the taps but could not figure out how to remove valve stem from valve body to replace any bad o-rings or seals. Anyway I ended up putting on a new valve body on the old taps and afterwards looking at old valve body more closely was able to figure out how to remove valve stem to access o-rings. It was a rubiks cube. See photos in case you have similar problem. http://s1121.photobucket.com/albums/l511/jayherenow/oateysinglehandle/ |
| Perseverance. That's how I've ended up with a basement full of things that I repaired after DW replaced them. |
Return to the Plumbing Forum
