Return to the Plumbing Forum
Please help identify this shower valve trim
chasent77 (
Mon, Dec 10, 12 at 8:08
| I am hoping to replace the shower valve trim and am hoping you can identify it without me having to take the trim off the valve. The screws are attached at 2:00 and 8:00, and under the lever there is a cursive lower case "m" with a circle around it and an SA that run together with a circle around that. I've attached pictures and any help you can provide would be most appreciated. |
RE: Please help identify this shower valve trim
| A straight-on view might be helpful as well. |
| Original shower head still with it? Might say it there. |
| Sadly, the original shower head was changed right after we moved in and I didn't think to keep it. |
| The circle with the SA is the CSA seal marking. I call it the 'Canadian Seal of Approval", though it is probably something else. (Canadian Standards Administration?) They are a testing group like Underwriters' Laboratories. It means that the product can be sold in the US and Canada. |
| Nothing else stamped into the plate? Wipe it clean with a wet paper towel and take a closer look, esp near the top and the bottom. |
