| The bathroom sink had been draining very slowly and a chemical drain cleaner
was used one week ago. It did not solve the problem, and I want to try using baking soda and vinegar before getting more help. But have read that its not good to put those in if chemicals have been used.
The sink does very slowly drain so am guessing/hoping that the chemicals are all
===> Do you think its safe after one week to try the baking soda and vinegar ? PS I would have removed the jbend first but the sink is a pedestal sink, and the pedestal
Thanks for your suggestions and comments. |
- Posted by mydreamhome (My Page) on Tue, Dec 6, 11 at 9:48
| Just a question (and you may have already done this), but if not, it may lead to an easy fix--have you pulled the stopper out of the drain in the sink to clear the upper part of the drain of any hair or objects that may have slipped down but gotten caught on the '+' in the drain thereby restricing flow? That has been our problem everytime with a slow bathroom sink drain. A few minutes & a pair of tweezers does the trick. Hope this helps! |
- Posted by jakethewonderdog (My Page) on Tue, Dec 6, 11 at 10:26
| You are probably fine using the baking soda/vinegar at this point. Here's the thing: Bathroom sinks get nasty glopps of soap, hair, shaving stuff, tooth paste, etc. + probably some growing stuff. Nasty, to be sure. A big part of the problem is that there often isn't enough water to wash it all the way down the drain. Remove the stopper if you can. Block the drain and fill the sink full with warm, soapy water. Open the drain and plunge it with a sink plunger while keeping the overflow blocked with a damp rag. That should remove most of the nasty stuff that's clogging the pipes. Repeat until you have a fast running drain again. |
| Put a shallow pan under the trap and remove it. Remove the stopper and look down the line. Remove any junk you see. Also check the trap for crud. Some of the Chinese drain assemblies do not allow for removal of the stopper without unscrewing the actuator arm that enter the back of the tail piece. |
| If you have water movement through the drain, albeit slowly, there should be no risk from previous chemicals. However, I agree that you should take it apart and fix it properly. Even when drain cleaners improve things, they often don't fix the whole problem. |
- Posted by jakethewonderdog (My Page) on Tue, Dec 6, 11 at 16:16
| I think that the OP is trying to avoid taking the trap apart for the reasons already stated. |
| "I think that the OP is trying to avoid taking the trap apart for the reasons already stated." And trying every half a** thing to avoid a real fix. There was enough room to hook it up, there is enough room to take it apart. |
Return to the Plumbing Forum
