New Construction Water Meter Size
Posted by eoz3106 (My Page) on
Mon, Nov 28, 11 at 22:08
The utility where we are building allows us to choose between a 5/8" x 3/4" meter and a 1" meter. Any reason I should choose one over the other? They are about $80 different, but a significany monthly minimum difference. We are a family of 4. Thanks.
RE: New Construction Water Meter Size
You should not choose... Your plumber should do a code "Fixture Demand Load" study prior to pulling a permit to install the water supply line and the code will define the required diameter of your supply line. The meter should then be sized equal to the supply line. The exception is 3/4" is the minimum size permitted for a supply line, but in instances where the fixture load demand is minimal, they may opt to install a 5/8 meter on a 3/4" line.
