Feedback requested: plumbing quote from GC
Posted by babushka_cat (My Page) on
Mon, Nov 29, 10 at 22:06
In prep for a kitchen remodel on my 1942 cottage my GC is doing some preliminary plumbing work this Wed: replacing water heater to tankless which will allow us to eliminate an exhaust flue running up the back of a kitchen cabinet and upgrading some of original galvanized plumbing to copper. (we cannot do all of the galvanized due to the phasing of the project, some will be done during kitchen remodel)
the contractor makes reference to a 1" bell and 1/2" lines. is this is an acceptable design solution. any concerns with this approach i should be aware of? i appreciate any feedback you have. i have an existing irrigation system connected to one of the hose bibs - any worries about this functioning correctly after this plumbing upgrade? scope of work is listed as follows:
COPPER SUPPLY
provide and install 3/4" copper to a riser at front of residence
provide and install a shut off ball valve at exterior of residence
provide and install a 3/4" to 1" bell (what is a bell - any issues with going to 1" from 3/4"?)
re-install electrical ground clamp
provide and install 1" copper line from shut off valve to water heater
provide and install 1" x 1/2" T's for front hose bib, bathroom and laundry cold supplies
provide and install 1/2" hose bib for front hose bib
provide and install dielectric connectors at all ties of existing galvanized to new copper (this is in reference to the galvanized lines we cannot yet abandon due to the phasing of the construction work)
TANKLESS
remove existing water heater
provide and install 1" gas line from meter to water heater location
provide and install Takagi TK3
provide and install isolation valves
provide and install condensate drain
provide and install tie to new 1" supply line
provide and install tie to existing distribution
provide and install stainless steel ductwork from water heater to exterior of residence
provide and install flue exterior wall termination
RE: Feedback requested: plumbing quote from GC
Sounds fine.
A 'bell' is a short increase in pipe size done so that a pipe of the same diameter can fit into it. In your case the plumber is upsizing from a 3/4" diameter water service pipe to 1" distribution pipe once inside the structure.
That's a good practice to increase flow to fixtures.
Installation sounds fine.
