Mon, Nov 26, 12 at 20:17
| Hi. I have an old house (built 1939) with an inset cast iron tub. The drain is slowly leaking. I bought a tub drai wrench - two actually a and broke both I the process of trying to get it to budge. Even with all my strength and adding an 18 pipe for leverage (for what I estimate to to about 1500 inch lbs of torque) I couldn't turn it. So now I'm left with two options. I can try to Dremel it out but I'm concerned it is so old it may now be a standard size or something like that and who knows the status of the pipe threads.. Alternatively, is there a product I can apply to the underside (like a plumbers putty or alternative) around the old gasket to help seal it, The leak is real slow so even just a little but might do it. What would you recommend? |
| Try copious amounts of WD40 and let it soak in for a few days. |
| PB Blaster or Liquid Wrench are better. Worst case use a small Dremel cutting wheel or stone to make notches in the ring and a chisel and hammer to turn it. |
| Sounds like a job I wouldn't want to do!!! :p |
Return to the Plumbing Forum
